Trans Vibration/grinding at Low RPMS??
Hello all. I have a 2000 f350 with a 6 speed transmission. When I go to pull out to pull out or when I am driving if the RPMs drop below say 1000, I have a grinding/vibration in my trans. I heard this was normal for some clutches, but I did not seem that sounded right. I could not tell you if it is an aftermarket clutch, I just purchased the truck, but it seems to drive great.
Let me know if anyone has any ideas. Thanks a bunch. |
it could be many things i would start with the throw out bearing.
It does it even when the clutch is not being used. So say I slow down on a road and the RPM's drop below 1000, it will make that noise, but right when I press the clutch in it goes away.
Could it still be the throwout bearing? |
That is where i would start. and go from there. It sounds like thow out bearing to me thou.
Any ideas?
normal noise when you lug down a 6 speed i drive 4 different ones and they all do it it is geartrain rattle.
