Which trans oil to use? - Ford Powerstroke Diesel Forum
Old 08-17-2009, 04:07 PM
Alright guys, I have read threads about which oil to put in my trans. I have read Dextron/ Mercon III, some say MerconV. Which ATF should be used in my trans? I changed my oil and refilled with Dextron/ Mercon III. Any help will be helpful.
Old 08-18-2009, 01:42 AM
!!!! BUMP!!!!
Old 08-18-2009, 02:22 AM
Other vehicle is an F250
This is what I use.
AMSOIL - Synthetic Universal Automatic Transmission Fluid (ATF)
Old 08-18-2009, 03:27 AM
WNY Biodiesel Co-op
There is a Ford TSB that states that there is a change in the recommended fluid . From Mercon III to Mercon V. Not sure which years , but I think its the early 2000 to present. I use Royal Purple Sythetic ATF.
Old 08-18-2009, 03:50 AM
wriott
Guest
Posts: n/a
amsoil here....
Old 04-02-2012, 08:52 AM
I am changing the filter and fluid in my 2002 7.2 4r100 and called Brian's Truck Shop. For a mostly stock (chip/intake/exaughst) he said "any mercon or dextron 3 non synthetic atf" and would not specify a brand.
I know this is an old post but since I was long here for advice I figure I would update it.
I was gonna use mobil 1 synthetic but it has changed formula and that's what got me looking.
Old 04-05-2012, 08:06 AM
Ur safe to use Amsoil ATF as posted above.. insure there are others, but I'm just suggesting what I use.
