Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 06-18-2009, 12:39 PM
AGENT ORANGE AGENT ORANGE is offline
Is thi Normal?
I've had the truck for 2 years. Ever since I've had it, I get a very light THUD when accelerate from a stop.
Is this normal?
Old 06-18-2009, 04:33 PM
U-joints maybe?
Old 06-18-2009, 04:38 PM
jamstoyz jamstoyz is offline
more info. what year? etc.....
Old 06-19-2009, 01:13 PM
2002, PSD, SRW, CC, 2WD, 4R100
I think it might be the carrier bearing.
Old 06-23-2009, 02:49 PM
emoryemt-i emoryemt-i is offline
Anything else about this Mine is doing it also
Old 06-23-2009, 04:57 PM
anyone
Old 06-23-2009, 05:07 PM
sikktruk01 sikktruk01 is offline
slip joint in the driveshaft. take it apart and lube it.
Old 06-23-2009, 05:11 PM
StrokedInMT StrokedInMT is offline
samething with my '08,,,,,,, any ideas?
Old 06-23-2009, 05:14 PM
if it's still under warranty let the dealer figure it out.
Old 06-23-2009, 05:15 PM
GreenF350 GreenF350 is offline
What he said. If you do a search you will find that this topic seems to be cyclic and comes up every once in awhile around here and quite often the solution is to take apart the rear driveshaft and grease it. GTG after that. Check everything else really quick, i.e. U-Joints, carrier bearing, trans mounts. If all of that is good then that is where my money is at.
-Aaron
