Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 06-16-2009, 11:07 AM
chigl chigl is offline
2001 F250 SD 4R100 Shifting Issues and Codes
Hi All,
I have a 2001 F250 4WD with the 4R100 automatic transmission with 69,000 miles. I run the Diablo Predator 85HP tune with firm shift points. In April I noticed the truck shifting rough from 1-2 and 2-3, slipping, having a rough high idle, and the Overdrive light flashing. The truck also completely shut off in traffic.
It threw the following codes:
P0238 - Turbo/Supercharger Boost Sensor A Circuit high
P0603 - Powertrain Control Module Keep Alive Memory Error
P0478 - Exhaust Pressure Control Valve High Input
P0470 - Exhaust Pressure Sensor
I reset the codes and did not have a problem for a month, but I also rarely drive the truck.
Today I experienced the same problems shifting, slipping, and overdrive flashing. In addition to the codes above, I also have
P0720 Output Shaft Speed Sensor Circuit.
I have a call in to the Ford Dealer, but am interested to see if anyone can help diagnose and provide recommendations. The Ford dealer wants $735 in labor alone and recommends an overhaul or rebuild, but will get back to me with better estimates.
If I need to put in a new transmission, what are the thoughts about the ATS or other? Any recommendations for a good transmission shop in Northern Virginia?
Thanks!
Old 06-27-2009, 02:46 PM
Ghillie Ghillie is offline
JMHO: Look into can Call Brian-->BTS www.brianstruckstop.com His shop is in Lead Hill, AR. Brian builds a very much so bullet proof transmission. If you can't drive too his shop, and have his crew install it for you... U can have brian ship his transmission to your local shop to have it installed. I myself am going to take the time to drive there, and have brians shop install it. That way I know it done right, with no short cuts.
Good Luck.
