Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 04-25-2009, 10:13 PM
MattM MattM is offline
installed new filter" problem?
I changed the fluid and filter in my transmission. When i installed the new internal filter, i seated the new filter in the filler tube with orange rubber washer, but moved the filter to the side to seat it further upwards. Normally the filter is poistioned straight back or parallel to tranny pan, but by mistake i installed mine more to the side or angled as it allowed me to push the neck of the filter a little further up into the "tube" area.
Make sense?
It has me wondering, the slanted pick up tube from the bottom of the filter is now about a 1/4"-3/8" raised from "stock" position facing the bottom of the pan.
Does it matter or should I just drop the pan and move the internal filter back to the normal stock position?
Old 04-25-2009, 10:28 PM
Austinj427 Austinj427 is offline
I would keep it in the stock position, it might have a tough time picking up fluid with it being higher up
Old 04-25-2009, 10:40 PM
cliford cliford is offline
yea i would change it back. i dont see any advantage to having it higher.
Old 04-26-2009, 10:08 AM
jbeasts10 jbeasts10 is offline
Lifetime Premium Member
I would move it back to the stock position.Not saying it will,but it could burn up your tranny if it cannot get fluid to it.
Old 04-26-2009, 07:06 PM
Moved it back and replaced more new transmission fluid with even newer fluid. LOL
