Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
  #11 (permalink)
Old 01-20-2007, 08:03 AM
Chad T Chad T is offline
Sorry I missed that Scott. Any other ideas? other than the tranny which I will run by a Shop I'm just asking around to see where to take it.
  #12 (permalink)
Old 01-20-2007, 10:40 AM
Is there any body else out there that might have an Idea of the slippage and vibration problem? Thanks in advance
  #13 (permalink)
Old 01-20-2007, 10:52 AM
djsdiesel djsdiesel is offline
Powerstroke Techie
Did you just buy this truck or have you had it and it has just started doing this. it sounds like a u-joint or driveline angle problem to me. A u-joint could be dry and binding up but still feel tight with driveline installed. Try removing the driveline to check the u-joints.
  #14 (permalink)
Old 01-20-2007, 11:11 AM
I did just buy the Truck in Oct. and it has always done since purchase. I'll check the U-joint and if it was the torque or clutch it would start to smell burnt soon? I hope it's the U-joint. Thanks
  #15 (permalink)
Old 01-20-2007, 11:14 AM
Powerstroke Techie
do you only get the shudder on take off?
  #16 (permalink)
Old 01-20-2007, 11:19 AM
not on take off it's when you start to accelerate in motion at any speed it feels like it hesitates(sluggish)and vibrates and then if you continue it will smooth out as it picks up speed or if you let off the accelerator it will smooth out also quickly
  #17 (permalink)
Old 01-20-2007, 11:26 AM
Powerstroke Techie
I would take it to a tranny shop and let them drive it, I misunderstood I thought it was on takeoff only. It does sound tranny related
  #18 (permalink)
Old 01-20-2007, 11:27 AM
Thanks and the u-joint sounded better though.
  #19 (permalink)
Old 01-21-2007, 08:58 AM
Deeno Deeno is offline
Originally Posted by Chad T View Post
Thanks for your help Deeno and I thought I was in the 7.3 tranny problems forum. Scott the truck is a 4x4 but stock height and I checked the u-joint. Just trying to run down an idea. Maybe a tech will have an idea.Thanks
Sorry about that Chad. I fotgot we were in the 7.3 tranny forum
Still asleep I guess
  #20 (permalink)
Old 01-23-2007, 05:44 PM
Anybody else have an idea. The only other info to add is it seems to do it when the tranny approaches the downshift point. thanks
