Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 10-18-2007, 06:08 PM
tubular031 tubular031 is offline
Wont shift out of 1st after fluid change
Ok this truck is starting to kill me!!
Just got the truck and took it to the shop to get all the fluids changed. They called me today and said that after they changed the tranny fluid it will not shift out of 1st gear. They are suppose to be trouble shooting it tomorrow. Seemed fine before they changed the fluid. Did they mess something up or is this going to be something easy for them to fix? I sure hope I am not looking at a new tranny
It’s a 01 F350 SRW with 160k on it.
Old 10-18-2007, 06:19 PM
PSDfan99 PSDfan99 is offline
Ok, not to make you feel bad, but I had a 99 f350 7.3L (not the one I have now, the one before it) and I had the tranny flushed at 130,000 miles thinking I was doing some good for the truck.... well 2 days went by after the flush and the tranny blew. The thing just wouldnt move and inch. Before I did the flush it shifted and ran great.... after, well not so well. I swear the flush caused my tranny to go prematurely, I should have never flushed it, I bet I wouldnt have had to rebuilt it if I left it alone.
Old 10-18-2007, 06:35 PM
jfines@cox.net jfines@cox.net is offline
I've heard that the power flushes are a bad thing.
I just had my trans rebuilt at 126,000 and the tech told me never to have it done. just change the fluid and filter regularly.
Old 10-18-2007, 07:05 PM
00strker 00strker is offline
ive heard flushes are bad also mostly on high milage trannys
Old 10-18-2007, 07:20 PM
sldghamr sldghamr is offline
there's a friend of mine who makes the rounds, his name: Murphy
Old 10-18-2007, 07:24 PM
sawyer1 sawyer1 is offline
I had mine flushed about two monthes ago and no problems so far. Knock on wood!!
Old 10-18-2007, 07:28 PM
when it rains it poors! or is it when it rains, I get poor.
I should have know it was too good to be true. This truck is beautiful and in great shape (sorta....) It was exactly what i was looking for.
dam you murphy!!
Old 10-19-2007, 03:46 AM
95BLKLSC 95BLKLSC is offline
You may have been better off with just a drain and refill. Although not even attempting to shift out of first may be an electrical issue such as the MLPS (senses what gear you are telling it to be in). I had one go on my lincoln and it wouldn't shift out of second, new $25 part took care of it. You have to be VERY carefull with alignment on this part, the slightest bit out and it will shift all screwey.
