Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 04-24-2007, 04:55 PM
odiesel80 odiesel80 is offline
I need some help!
I have a 99 250 4x4. The truck has 150,000 on it and the trans was rebuilt 35,000 mi ago. Only within the last 3 weeks I have been seeing elevated trans temps. i changed the fluid last week and the filter was pretty dirty as i suspected, but when i dropped the pan, two bolts fell off the valve body. i put them back in and torqued them to spec. also i noticed a few of the other bolts were loose too. when i went to tighten them, some of them tighten up, but a couple just kept spinning. i think that i am getting these elevated temps because the fluid is spraying out back into the pan without going through the cooler. is this right? the bolts rattling out and the ones that won't tighten scare me. what should i do? Also, on the highway the other day after driving for about 200 mi, the overdrive button started blinking.
Old 04-26-2007, 04:31 AM
ipz2222 ipz2222 is offline
The elevated temp is from slipping. The bolts that are spinning are stripped. Common problem because the threads are so small. this can and SHOULD be fix now. It can be done in the truck.
Old 04-26-2007, 05:07 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
You need to get those bolts fixed, if you keep driving it while the tranny is loosing pressure your going to burn up the trans and then your going to need a new rebuild.
Old 04-27-2007, 04:07 PM
thanks guys, i will have that done immediatley. my buddy told me about a process called helicoiling. i will have that done and hopefully that will be the fix.
