Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Trannie Problems
Old 04-24-2007, 03:58 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
urgent
im taking in my truck in 10min and was wondering on what all you guys thought about either removing or leaving the edge evo programming on it ..... should i leave it on it or remove it and install after they rebuild my tranny?
Old 04-24-2007, 04:03 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
i'd remove it. Are you taking to dealer or some tranny shop?
Old 04-24-2007, 04:08 PM
Rodslinger Rodslinger is offline
Gun Nut
Remove it man - no reason to give them an excuse.
Old 04-24-2007, 04:57 PM
K i removed it.... took it to my local AAMCO... i had done research on them and had talked to the maneger a few times and looked over their shop before i decided on them to do it... ill be getting it back friday afternoon so i cant wait.... you think i should get the mag hytec pan or just leave it stock? was thinking of putting a bigger oil cooler too before they fill it up with fluid.....
Old 04-26-2007, 04:28 AM
ipz2222 ipz2222 is offline
Any shop that works on these trans NEEDS to know what kind of chip or programmer you are useing. You need to also discuss this with them about the warranty. If you don't and you have trans problem and then they find out about the programmer, you may have a voided warranty. Be up front with them. The final test drive needs to be with and without the programmer.
The guy that uses his truck to pull his bass boat does not get the same rebuild as the guy who pulls a 12,000 lb work trailer. Preston
Old 04-26-2007, 07:12 AM
well all they are doing is installing the kit... i had TCI build me a kit that will be able to handle anything i dish out now and with future mods..... they already know about the tuner/programmer... if i actually broke a part i would have to go to TCI... all AAMCO is warranting is that they installed it correctly... thanks for the info
-Raul
Old 04-26-2007, 07:21 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
How much did TCI charge you for the trans.
Old 04-26-2007, 08:13 AM
well it wasnt an off the shelf item... most of the parts were specially made for me thats y it took them 3 weeks to get it to me.... they had built this kit for a powerstroke making over 600 hp.. tractor pullling truck.... so they offered me a discount price since i am a dealer.... if you want to know the price i can pm you but the retail price on this tranny "According to them" is lil over 6k for the complete built tranny.....all i did is have them ship me all the same parts instead of haviing them build it for me so i saved a lil on that.... let me know if you have any other questions..'
-Raul
