Fuse blowing problem - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-05-2007, 04:43 PM Thread Starter
I have 99 F-350. The problem is the injection control module fuse keeps blowing thus killing the motor.After checking all over, I found the wires somewhat melted near a plug on the back of throttle housing. I put new plug end on and restarted. It ran fine for about an hour. Tried to go down road, 2 miles later same fuse, poof!!! I put jumper wire in to get back to house without a meltdown. Checked the same wire but its OK. Any suggestions or ideas would be great.
chaser0162 is offline
post #2 of 8 Old 02-05-2007, 04:44 PM
is the plug your talking about on the back of the fuel filter housing?? im wondering if your reffering to the fuel heater plug....if thats the case just leave it disconnected for now and replace the fuel heater...
mschn99 is offline
post #3 of 8 Old 02-05-2007, 04:49 PM Thread Starter
Yes, its behind the filter housing. Could that be shorting out inside causing it to blow the fuse?
post #4 of 8 Old 02-05-2007, 04:56 PM
yes...your fuel heater is shorted....disconnect it for now and it should start (with a good fuse) and then replace the fuel heater when you get a chance...
mschn99 is offline
post #5 of 8 Old 02-05-2007, 04:59 PM Thread Starter
Thanks,I'll give it a shot.
post #6 of 8 Old 02-05-2007, 05:03 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Marc is Da Man!!!! Just a little Yooper talk Welcome to Powerstroke.org as you can see its the place to be!
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #7 of 8 Old 02-05-2007, 05:11 PM Thread Starter
At least someone can point me in some direction, instead of the old "just bring it in and we'll find the problem".$$$$$$$ I don't have to spend for someone else to look, I have eyes myself.
post #8 of 8 Old 02-05-2007, 05:23 PM
vitalidle's Avatar
Plus you get the satisfaction of learning and actually fixing the problem yourself! Gotta love it
Auto 93,000 miles
DP Tuner F5
