Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 06-21-2009, 10:16 PM
excelwelder excelwelder is offline
Cool I just replaced injectors & glow plugs .I NEED HELP
So I just replaced all the injectors and glow plugs on a 2000 7.3 ltr.
One big problem I forgot to blow out all fluids from the cylinders before I put it back together and the motor wont turn over do to hydro-lock.Can any one tell me if there is any way besides tearing it back down to get the fluids from the cylinders.
If I let it sit will they leak out?
Thanks for any help
Old 06-21-2009, 10:21 PM
perfection perfection is offline
Buckeye Power Strokes
Send a message via AIM to perfection
i have no idea how so heres a bump
Old 06-21-2009, 10:29 PM
03Powerstroker6.0 03Powerstroker6.0 is offline
good god.
Old 06-21-2009, 11:04 PM
Dirk Dirk is offline
Diesel Innovations
Pull the valve covers.
Remove glow plugs.
Turn the engine over by hand 5-6 times, wait 5 minutes, turn 1-2 more times.
Replace glow plugs/valve covers/rest of parts.
Pray.
Pray that you didn't bend a rod.
Old 06-21-2009, 11:06 PM
Diesel Innovations
If there is damage, hopefully you just bent a few push rods and not a connecting rod. Or maybe crack a few rockers.
Old 06-21-2009, 11:07 PM
Thanks .I didnt try to turn it over after the 1st bump It all clicked, I forgot to blow out the fluids . I sure hope i didnt.
Old 06-21-2009, 11:09 PM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
You turned it by hand I hope. Probably best to pull the glow plugs and turn the eng. by hand/breaker bar. Pistons have a bowl shaped in the top of 'em that oil will just sit in until it's dealt with.
Old 06-21-2009, 11:12 PM
Diesel Innovations
depends on how much oil/fuel filled the cylinder and at what point the piston is in the cylinder. If he turned the engine over with the starter.......
Nope .I went to start it and as soon as i heard the hydro lok sound I stopped and just let it be . Well thanks for the info that was my next ? if I let tit sit will it leak bye .But you anwsered that Thanks.
Old 06-21-2009, 11:14 PM
Diesel Innovations
It will not leak by...
