Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #21 (permalink)
Old 06-24-2009, 08:52 AM
excelwelder excelwelder is offline
thumb:will do ,thanks for the info
  #22 (permalink)
Old 06-24-2009, 09:06 AM
kylev90 kylev90 is offline
stuff rags over everything when u do crank it by hand. Even just a slow crank blows oil EVERYWHERE
  #23 (permalink)
Old 06-24-2009, 09:08 AM
wow way behind sorry
  #24 (permalink)
Old 06-25-2009, 03:47 PM
all is well thanks for all teh help!
  #25 (permalink)
Old 06-25-2009, 05:08 PM
wriott wriott is offline
BUILT & BROKE BY ME
good glad to hear that you got it going.
  #26 (permalink)
Old 06-25-2009, 09:54 PM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
So what was the issue?
  #27 (permalink)
Old 06-27-2009, 11:53 AM
Not sure ,its running good but i still sm getting codes
p1105
p1106
p1316
p0541
p1275
Iam not sure what these mean ?
any help
Thanks for all of the help
  #28 (permalink)
Old 07-02-2009, 07:56 PM
larz18 larz18 is offline
p0541=manifold intake air heater open circuit
p1105 = dual alternator upper fault monitor circuit failure, alternator failure, pcm
p1106= dual alternator lower fault control circuit failure, alternator failure, pcm
p1275= high to low side open #5 cylinder, open circuit, open injector, failed idm
p1316= injector circuit / idm codes detected
hope that helps, sounds like you have some major voltage idm and pcm issues. i would start with your alternator then idm then pcm. might want to get everything tested
