So like my earlier post stated, I thought my codes were perfect when I ran them, but found out that my OBDII fuse went out, so when I ran the codes with the new fuse it stated that nothing was wrong. Bummer, now it is like a guessing game. Anywho my 2000 PSD is cranking very hard and has more than enough juice to turn over, but won't. I have two new batteries. I live in the Rockies so it is very cold. Fuel system was a go as I took off the fuel pump and got fuel from both ends. Replaced the fuel filter too. I run Diesel Klean in my system and there is zero gelling. When I try to turn her over a light white smoke comes out of my tail pipe. Could it be the glow plug relay deal that is located by my fuel filter housing? PLEASE HELP!
very weel could be glow plug relay problem ,need to test it to see if its working
Hard start?
What weight oil are you running and what are the temps?
