blue smoke condition, need advice - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-19-2009, 06:11 PM Thread Starter
Hawker's Avatar
A couple days ago, i noticed while sitting on a hill at a light, i would get some blue smoke puffing out when the truck was at idle. jump on it, and it went away.
now, i notice the blue smoke when i'm on it hard, and mixed with black smoke when i get on it from a stop. it's not terrible, but it's noticable. and it's all while on an 80hp economy tune. the truck doesn't run rough really, but i do think it could run a little smoother.
when i'm coming down hill to a stop, or on an off ramp and finally get close to a stop, and the trans unlocks, the rpms drop down to almost 500, like it almost wants to stall and then it goes back to normal, if that has anything to do with it (brand new IPR in december)
99 F-450 Crew Cab
DP 80E/80T/120R
ISSPRO gauges - auto conversion - built trans & billet triple disc
EBPV delete - Wicked Wheel
zoodad-aih delete-ccv
"If a big hammer won't fix it, you've got an electrical problem"
Hawker is offline
post #2 of 6 Old 06-25-2009, 06:15 PM
RadarRider's Avatar
I'm wondering if you've got a cracked injector......anyway here's a
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #3 of 6 Old 06-25-2009, 06:36 PM Thread Starter
Hawker's Avatar
believe it or not, i'm pretty sure it had too much oil in it. i took 2.5 quarts out and re-routed the ccv back to stock and i haven't seen any smoke since.
99 F-450 Crew Cab
DP 80E/80T/120R
Hawker is offline
post #4 of 6 Old 06-25-2009, 06:42 PM
RadarRider's Avatar
The only thing I can think of is valve seals, then. Not sure, Hawker. Here's yet another
post #5 of 6 Old 06-25-2009, 06:51 PM
twhetten's Avatar
Have you taken the oil fill cap off while it is running to see if you have any blowby, this sounds like what happened to my '97.
Ty-'03 cummins 482hp/1078tq (sold)
'05 F-350 4x4 shortbed dually
EGR delete
6.4 banjos
Ford blue spring
CAI with CCV mod
SCT tuning by Innovative
FICMrepair.com upgraded FICM
'04 F-550 hauler
Full air ride
'92 W250 cummins
'67 kaiser M715 (shoehorning a 7.3 idi in it right now)
twhetten is offline
post #6 of 6 Old 06-25-2009, 07:56 PM Thread Starter
Hawker's Avatar
the blowby has been the same, maybe a little bit more when i switched to synthetic.
99 F-450 Crew Cab
DP 80E/80T/120R
Hawker is offline
