Dead in the water 2000F350 Dually - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-04-2007, 10:27 AM Thread Starter
bevansracing's Avatar
Well 7 months ago I replaced my alt. and both batts. A few weeks ago it wouldnt start one morning so I jumped it off and took it to my buddies shop.Well after a coulpe of weeks of no start in morning and not finding the drain we isolated it to the alt. ,suppose it had a bad voltage regulator so we replaced it and lo and behold the next morning DEAD, by this time I am freakin out but he thinks we got a bad alt. from his supplier so on goes the third one. Next morning I turn key and truck is dead {temp out side is 40] so I jump it off and take it to my buddys shop and he put in two new batteries and it has started up two mornings in a row.I plug my block heater in so I will have heat for my kids but this shouldnt affect anything.Now the whole time this was going on once you jumped the truck off it would run and start all day but let it sit for more than 5 hours and dead!!!!! Needless to say I am so frustated and so is my boss due to being late from the truck not starting and the droppin it off at shop and so on , he is pushing me to sell it and buy an 2008 but this is the first time I havent had a truck or car note in 15 yrs. On the other side I am spending the money I was saving on repairs so its kinda a wash.I just bought this truck in may of 06 and other than the alt.,batts,and 8new injectors I have a pretty nice truck but now I feel I cant trust this truck.
bevansracing is offline
post #2 of 18 Old 02-04-2007, 04:21 PM Thread Starter
Well i tried to start it a little while ago and my new batts are both dead so i unplugged the new alt and am charging the new batts anybody have any ideas ,,,,my buddy is stumped and doesnt have time to mess with it as he teachs autoshop so can only work on it 1 or 2 hours a day. Should i take it to an auto electical shop or the dealership ,PLEASE any help would be gratefully taken
post #3 of 18 Old 02-04-2007, 04:47 PM
straycat's Avatar
I have heard that the heater in the y pipe can short out and cause a draw on the system, you could check that by unplugging it and see if it stops the drain. I have a set of isolators on my batteries that shut them down if the voltage drop to a certain point. If they kick off, I just hit the remotes for them and it reconnects the batteries to start, and I have to reset the radio stations, but beats having to jump start every time i forget to turn something off.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #4 of 18 Old 02-05-2007, 04:30 AM
ADMIN AND TECH
SCUFFY828's Avatar
need to get somene to run a draw test on electrical system , if someone knows how to do it right t shouldnt take that long to figure out what the draw is ,a draw test is where you run an amp meter between unhooked batter cables ,start pulig fuses till amp gauge drops showig o draw and then find which components are o that circuit ,then pinpoint down the problem, like i say ,a person hat knows how to do this ,shouldnt take that long
ITS STOCK
SCUFFY828 is offline
post #5 of 18 Old 02-05-2007, 09:40 PM Thread Starter
Well we ran a draw test and it still only draws when the alt is plugged in . w
We jiggled the alt wires and the draw went away but if you turn the key on and off it cimes back. Does this sound like another bad alt or is my truck fried!!!!!!!!!!!!!!! My boss has given me the ultimatum YOU GOT # DAYS TO GET IT FIXED OR GO BUY A 2007 which I just cant swing the payments on a 55000.oo dollar truck,I paid cash for the 2000 plus repairs and thought i got a good deal but this is fixin to cost me my job.
post #6 of 18 Old 02-05-2007, 11:44 PM
straycat's Avatar
If it gets down to your job, take it in and rent or borrow something to get you back and forth until it's fixed. Don't mess with your livelihood, just geterdone.
Gord.
7.3 AUTO 4.10s
DP 6P 140EX.
AFE MAG F STG 2.
500LTR FUEL TANK
BILLET GRILL
35' GOLDEN FALCON
straycat is offline
post #7 of 18 Old 02-06-2007, 04:38 AM
ADMIN AND TECH
SCUFFY828's Avatar
if only draws with the alternator pluged in ,sounds like thats your problem ,are you using ford alternator or aftermarket and how much was your draw
ITS STOCK
post #8 of 18 Old 02-06-2007, 06:22 AM Thread Starter
1 1/2 amp and rebuilt alts
post #9 of 18 Old 02-06-2007, 06:30 AM
ADMIN AND TECH
SCUFFY828's Avatar
that is to much pull, like i say though if you unplug the alternator and it goes away , could be the alternator ,or possibly wiring to alternator ,maybe thats why you have had repeat repairs
ITS STOCK
post #10 of 18 Old 02-07-2007, 05:28 PM Thread Starter
put on motorcraft alt SAME PROBLEM
Put on a new in box ford alt and still have same problem,we have pulled every fuse in truck and still same thing! I am wondering whether to put a switch in alt wire to turn off alt when truck is parked.I took it to the dealership and 613dollars later they say nothing is wrong with my truck.But they replaced my new alt with another ford alt and drove truck home and once again the back of the alt is magnetic until you disconnect alt then it isnt.Plug it back in and you have a draw,,,,,,,,what gives.I pull a gooseneck for my company so i have to rent a truck while mine is in shop and so far it has been 125 a day that i am paying for a dodge with a gooseneck hitch and this has been going on for 3weeks. the 1500 i spent on a rental should have gone into truck.I talked to dealership about a new truck but now they say mine has a problem and will only give me 10000 for it and i have 20000 in it now.has anybody heard of a draw through the alt when the voltage reg is good or is something blowing my new alts up. PLEASE HELP!!!!!!!!!!!!!!!!!!
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstroke.org/forum/99-03-7-3-motor-problems/9899-dead-water-2000f350-dually.html
Posted By For Type Date
Dead in the water 2000F350 Dually - Ford Powerstroke Diesel Forum This thread Refback 02-06-2007 06:45 AM
