Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #31 (permalink)
Old 06-16-2009, 10:13 AM
Dirk Dirk is offline
Diesel Innovations
You will need to put the truck on a scanner and monitor the datastream as stated before. PID's to monitor, batt voltage, ICP, RPM, and IPR dutycycle. Voltage reading low or randomly dropping will cause it to die and not restart. It's random, but I've seen that a few times, That will be a short in the harness somewhere or bad cables. You should see RPM's jump to 200-250 when cranking. If you don't see rpm's, it's a harness issue, CPS sensor, or connector issue. ICP should quickly raise to 600psi+ when cranking and IPR duty cycle should raise as well.
Are you positive you are getting proper fuel pressure at all times?
  #32 (permalink)
Old 06-16-2009, 10:15 AM
snowman snowman is offline
Not sure on the fuel pressure but motor dies with out sputtering cutting out or anything else
  #33 (permalink)
Old 06-16-2009, 10:16 AM
Diesel Innovations
Then your fuel pressure *should* be fine.
  #34 (permalink)
Old 06-16-2009, 10:18 AM
Re the fuel if it is any of the filters or injectors or other fuel system wouldn't the engine sputter, cough extra?
  #35 (permalink)
Old 06-16-2009, 10:20 AM
  #36 (permalink)
Diesel Innovations
Yep. You'll notice pinging, coughing and a burp. THen dead until the pump cools down and starts working again.
  #37 (permalink)
Old 06-16-2009, 10:23 AM
would it throw a code
  #38 (permalink)
Old 06-16-2009, 10:28 AM
Diesel Innovations
Nope....
MAYBE a injector related code, but generally not.
  #39 (permalink)
Old 06-16-2009, 10:33 AM
thanks for the help
  #40 (permalink)
Old 06-17-2009, 11:18 AM
Diesel Innovations
THis will help you as well...
99-03 7.3 engine wiring harness diagram... Every 7.3 owner should have...
