7.3 oil leak - Ford Powerstroke Diesel Forum
Old 06-09-2009, 06:34 AM
7.3 oil leak
I have a 2003 7.3 FX4 with 90k miles. I have a oil leak that is puddling under the fuel filter and running down to the ground. It appears that the valve covers are dry. Where should I start looking for likely problems. Could the turbo leak oil? Would it hurt if I pressure washed the cold motor to help see where it is coming from?
Any ideas you have are appreciated.
Thanks
Foxhole
BR LA
Old 06-10-2009, 08:00 PM
Anybody have any thoughts at all?
Old 06-10-2009, 08:56 PM
Oil Leak
Oil puddling under the fuel filter housing is most likely HPOP o-rings, or HPOP mounting gasket.
Old 06-10-2009, 09:07 PM
Mine leaks out of the front of the oil pan.
Old 06-12-2009, 08:41 PM
Thank you for the replies! I am going to try to clean it up and see where it is coming from. This is a great site.
Old 06-15-2009, 08:40 AM
Oil Leak
So what did you find?
Old 06-16-2009, 06:59 AM
I haven't had time to take a look. I recently switched from Rotella T to Rotella Syn. Could that have caused the leak? I will report back what I find.
Thanks
If you cant fix it with a mall. It's a electrical problem.
Old 06-16-2009, 10:42 AM
I appear to have a similar issue.... Oil in the valley starting right under the fuel filter and running back and down. I checked the O rings on the HPOP last night and didn't find any oil to the touch, its also a slow leak just a couple of drops every time I park. In reading about the O rings going the leaks seem to be very impressive...
I am thinking its the lower HPOP gasket....Sound plausible?
