Oil in IC pipes - Ford Powerstroke Diesel Forum
Old 06-05-2009, 10:47 PM
Coal Rolling = Posing
Oil in IC pipes
So, I know I'm gonna have some oil in the IC pipes with an old turbo, but when I was puttin a new one on today, I found this in the pipe FROM the IC...
And I'm thinkin that's bad...
So, big brain please tell me how bad. Do I need to pull my IC and drain it?
Just seems like oil wouldn't make it that far without something bein bad wrong.
Did I fix it when I replaced the turbo? I KNOW I KNOW, that the TN is not the greatest thing to run... It'll never see over 350 hp. I promise.
So please don't turn this into a TN bash...
Old 06-05-2009, 11:08 PM
On note, I replaced the turbo because I got a good deal on the TN, not because it went out or had noticeable problems. Other than the usual surge.
Old 06-06-2009, 12:41 AM
Because of the CCV its pretty normal. I have a tn aswell. No problems in 8K, so fingers crossed.
Old 06-06-2009, 06:04 AM
Lol, cool!
Old 06-06-2009, 06:22 AM
Yeah, I've seen this on every IC pipe I've ever had off. (And that's hundreds) At first I thought the same thing.. this is bad... but in the end it's normal.
On a side note.. the amount of oil that does go through the IC in my opinion is a huge reason the EGR's coke up so bad.
Old 06-06-2009, 06:26 AM
Right on man. Thanks!
I don't have an EGR, but I do have an ugly engine thanks to this... Well, partly thanks to this...
Send a message via AIM to nccatfan
Blow-by gets run back thru the intake, so some oil is acceptable. You'll know when a turbo oil seal has gone bad... will smoke like a freight train and oil will come out the exhaust!
Old 06-06-2009, 02:02 PM
Yup, totally normal. In fact yours looks better than mine did last month...
Old 06-06-2009, 02:06 PM
Cynic
If there wasn't oil in my IC or CAC...
I'd be worried.
Old 06-06-2009, 07:29 PM
Alright cool. Thanks guys. I guess I won't try to blow out or drain my IC. My first thought was, that IC has got to be about half full for oil to be gettin up here.
I didn't think I was using that much but hey???
