OIL LEAK Question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-01-2007, 11:05 AM Thread Starter
Veggie-Destroyer's Avatar
OIL LEAK Question
HI MY DIESEL GODS
here;s the deal .
First I read the tech filles on oil leak .
and know this much its not at turbo or pedistal .
mid engine has some veggie but not engine oil .
at the bottom of engine a find oil on front radator hose
and the suspension not so much on oil pan. or belll
Its like few drops over night . now a 2in stain
i think it only leaks while running ..im thinking the hpop o-rings are leaking
which i guess is beyone me and my vice grips and duct tape ..
if this sounds like i'm on the right track plz tell what the dealership damages should be???? is this 250 . or or
Veggie-Destroyer is offline
post #2 of 8 Old 02-01-2007, 11:30 AM
ADMIN AND TECH
SCUFFY828's Avatar
what year and engine truck
ITS STOCK
SCUFFY828 is offline
post #3 of 8 Old 02-01-2007, 12:41 PM
International Threat
Marty's Avatar
He has the 7.3 and it's either a 99 or 2000 if IIRC.
Hpop Orings are CAKE - do not be scared to do them yourself. You can buy the kit from Ford for about 25-30 bucks or just get some #5 and #6 Boss Orings from a local hydraulic shop. You'll also want some Red Locktite for the fittings.
Let us know more info and if you find the leak. This quote helped me find my oil leak "oil will spray everywhere but forward"
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 8 Old 02-01-2007, 12:46 PM
ADMIN AND TECH
SCUFFY828's Avatar
yes hh pressure pump o-rigs are very common on 7.3 , but to be leaking of front of the motor and not out the back makes me wonder if it is possibly front crank seal, oil pump o-ring or even a oil galley plug on the front of the motor , if hpop o-rings are leaking the majority of the oil should be in the valley and dripping out the back of the engine , alot of times it helps to steam engine off and then get a good look at where oil is coming from
ITS STOCK
post #5 of 8 Old 02-01-2007, 01:10 PM
Powerstroke Techie
djsdiesel's Avatar
Are you running veggi oil?
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #6 of 8 Old 02-01-2007, 01:20 PM Thread Starter
moe info
O yea this motor is 02 7.3 that was dropped in the 00 excursion from local recycler
front end was wrecked out of 02 f 350 100k
.now out of warranty I dont even want to think about front crank seal or oil pump stuff but we 'll cross that bridge when we get there
.but front end collision hmmm..
I will clean off try to find again . but main valley is clean .
i'll let you know what i can find thank you for tips
fuel is 75% veggie 25 diesel
post #7 of 8 Old 02-01-2007, 06:54 PM
Lord Tauk's Avatar
Kinda hijacking..
Anyone ever use dye to help find leaks with the help of a blacklight? Is this even available to the public? My Grandfather has an 04 6.0, getting some recall work done a while back he mentioned Ford using a blacklight to search for a leak after adding some particular dye.
I don't see why it wouldnt be available from Ford or even wouldn't be any household dye you can find off the shelf in a store.
Lord Tauk is offline
post #8 of 8 Old 02-02-2007, 03:56 AM
ADMIN AND TECH
SCUFFY828's Avatar
does have to be dye made for engine oil, can be bought at any part store, alot of tool distributors ,carry the blacklight for checking it
ITS STOCK
