truck dies, need help
Here's whats happening.
Truck started dying, once it died, it is very hard to start back up. Once is fires back up, you have to give it 1/2 throttle for it to slowly pick up rpms. Then start driving it again, it warms up, problem seems to lessn to just a miss. Pulled codes, these is what was in the truck: p1212 ICP not at expected p1247 Turbo Boost press low p0340 Cam Pos Sensor Ckt Fault p0732 Gear 2 incorrect ratio I cleared the codes, ran a buzz injector test which came back no errors, checked data and injector psi is round 500 at idle to 2300 around 3/4 throttle. I drove the truck about 2 miles after clearing codes, scanned again, and still have the p1247. Any ideas. I'm going out to the truck now to crawl under it and look at the wiring to the ICP and Cam shaft position sensor. Also going to check HPOP resivour. Oh yeah, FIRST POST! dmoss |
P.s.- I forgot to say "Welcome to the Org.!"...........
well, I found it was low in oil, so I put oil in the truck, unplugged the camshaft sensor and cleaned it with electrical cleaner, along with map sensor plug, fixed the wastegate signal line, fired her up, and she's been per-que-lating ever sense! (running like a top!)
Thanks for the forum though, I got a lot of good tips from here! moss |
