Help! Truck just up and died - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-02-2009, 03:56 PM Thread Starter
Last week many of you know my 2002 F250 7.3 just died while driving. I assumed it was the cps and I replaced it with the spare I had. Today driving home from work it happened again. Truck just shut off as if you turned the key to off. No warning lights, no bucking or anything just dead! I think it would be unusual to have my 2nd cps go out only 3 days later and 15 miles on it.
If not the cps what do we know could cause this.
After the truck died it would not start. I unplugged my chip and it still would not restart. Fortunately I died only a block away so in about 2 hours I will go see if it starts once the engine cools off, not that it was hot but this is what I did when this happened last Friday only I let it cool so I would not burn the crap out of my arms putting in the new cps.
If it starts then I am really baffled....Help suggestions needed
2002 F250 7.3 PSD Crew Cab.
4" Borla exhaust with 5" tip
Airaid intake
BullyDog 6 Position 4 Bank Chip
AutoMeter Pyro & Boost on pilar
Nothing better than seeing the look on the face of the kid driving the Mustang thru my rear view mirror.
Dang I just got creamed by a truck
Scooterdog is offline
post #2 of 18 Old 06-03-2009, 06:26 PM
I am having the same problem with our Excursion, thought it had something to do with my electrical problem but nope CPS was changed a year ago now I'm lost Snowman
snowman is offline
post #3 of 18 Old 06-03-2009, 06:29 PM
Quoted: 5 Post(s)
tach moving when you crank her over????
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #4 of 18 Old 06-03-2009, 07:09 PM Thread Starter
Tach does not move when cranking
My guy at Ford said it was throwing some strange codes between the ICP, IPR, PCM and ECM. The electrical values were off so they think there may be a short. They could not get it to shut down so they they are keeping it overnight and will run some more test in the AM. Nice thing is, since I do a lot of business with them they aren't charging for all of the diagnostics. I'll let you know what I find out tomorrow.
Airaid intake
post #5 of 18 Old 06-03-2009, 07:18 PM
Good luck please post results
snowman is offline
post #6 of 18 Old 06-03-2009, 11:37 PM
Quoted: 5 Post(s)
Well, typically if the tach does not move, it's the cps. But if your ford guys on it, I'm sure he'll get her going for ya! Good luck bud.
ianstew is offline
post #7 of 18 Old 06-04-2009, 06:41 PM
What did ya find out???
Amnima is offline
post #8 of 18 Old 06-05-2009, 01:58 PM
avrgrease's Avatar
thats pretty much exactly what i am getting. odd icp codes, and the truck never dies when im at my mechanics place. after i changed the oil, it hasnt seemed to die again. although when my truck was dieing, it was definatly hot. not unusually hot, but running at engine temp. my mechanic believes it might be the icp control module, but no one is for sure yet. ill keep posting as time passes.
02 7.3 crew cab, grease burner
02 7.3 ext cab, grease burner
professional grease collector and bio-diesel enthusiast
avrgrease is offline
post #9 of 18 Old 06-05-2009, 04:18 PM Thread Starter
Yep still in the shop and I think they have it nailed down to the ICP. They also had a hard time getting it to shut down but finally did today. he wants to keep till Monday to make sure. Well see what happens but I'll let you guys know.
Airaid intake
post #10 of 18 Old 06-10-2009, 12:09 PM Thread Starter
Ok here are the 2 codes ford is getting. P1211 (ICP I think) and P1248 (boost) they think that one is wierd. They got the same codes with and without the chip. Wiring harness and IDM check out fine.
Airaid intake
