2000 Problem
Hi - I am trying to avoid paying the local Ford Dealer $185 to tell me whats wrong with the 2000 Excursion with 110,000 miles on it. It had the Timing Senson replaced at ~50,000 miles.
Here's my problem: When I get to a stoplight, it will just stop running. I turn the key off and then start it - it will run fine. It has done this four times. While driving, it will have a hard shudder for a second and then keep running fine. It has done this three times. Can anyone give me some advice to the probable cause of this? Thanks, Morgan |
Welcome limegold. That sounds like a PITA. mschn99 will probably have a good idea of where to start.
Hi and thanks! I guess i'll take it in. The shudder is definatly not the trans. I also have a Jeep Liberty Diesel and they have the worst Torque Convertor ever put into a vehicle. They could rename the Liberty CRD to the 'Liberty Shudder'. Don't let anyone you know buy a Liberty CRD.
The problem that the Excursion has is the engine stopping for a second and then continuing to run. It will make you pucker for a second, as it usually happens on the freeway. I use the cruise control alot and it will turn it off when it happens. |
Does it quit when you hit a bump? Could be a short, maybe in the ignition switch...it it touchy at all?
Crank sensor could be bad agin not that uncommon.
Thanks! I ordered one and will try it. We just got some cold weather and the stalling has not been happening...
I just changed the Cam Sensor (Crank Sensor?) today and it seems to be running great! Yesterday, it stalled five times on a 10mile drive. Thanks for all the help!
I also noticed that it is time for a new water pump...anyone have recomendations on what brand to get? I have 110K miles, so I guess i'll do all the belts and hoses also...what fun! |
Go with a new water pump. The rebuilds are junk look for someone in your neck of the woods that is an Alliant dealer they have a new pump at a good price. If not make sure it's new from Ford or from an auto parts place. You can find a Alliant dealer on the web.
