Can't find block heater plug - Ford Powerstroke Diesel Forum
Old 01-28-2007, 12:14 PM
I have a 2003 F-250 Lariat with a 7.3. It never starts on cold mornings, below freezing usually. I see a lot about block heaters but I can't find my plug. Do some trucks not come with block heaters? Any suggestions?
Old 01-28-2007, 12:21 PM
im fat and ugly
some dont,
did you look behind the bumper on the passenger side
Old 01-28-2007, 12:46 PM
I found mine on driver side just behind the fog light. Hope it could help
Old 01-28-2007, 12:59 PM
i found mine on the driverside too....it never gets cold enough here to use it though....
Old 01-28-2007, 01:02 PM
i think after a certai year is was an option . you can look right on teh oil filte rhousing and see if the cor is connected. if theer is no cord then all you have ot do is go buy a cord. but element is always there.
Old 01-28-2007, 02:13 PM
duct tape & zip ties
first off look at where the oil filter connects to the engine. To see if you even have the cord. Because that is where it plugs into on a 7.3L. Then all you have to do is follow the cord to the front of the engine. It should be located behind the front bumper on the driversside bundled up and zip tied right behind the drivers side towhook.
