Oil Level
If the oil on the dipstick shows about 1/4 inch over high mark, will it cause the motor not to start?
It's highly unlikely unless it's friggin' cold where you are now. Have you had the CPS recall done to your truck? Can you get a scan tool & check for codes with Key On, Engine Off(KOEO) & also check for codes in continuous memory.
Waiting on scanner so I can check for codes. Changed the CPS, had lots of trouble with that before. Guess I will have to see what codes come up with scanner.
