Motor shuts off when reaching optimal temperature - Ford Powerstroke Diesel Forum
Old 05-13-2009, 08:27 PM
I recently got a 99 F350 manual.
It runs good untill it warms up then it shuts off ,when it cools down you can drive it again until it warms up again.
I did some research and i went back like 10 pages here also ,but nobody seems to have the same problem i got so any help would be greatly appreciated.
I know it's got a new fuelpump and filter.
Thanks
Old 05-13-2009, 08:31 PM
sounds like crank position sensor to me my truck did the same thing when it whent bad run till it got to normal running temps then would kill it's self then would wait about 30mins and it would run agin till it got that temp agin and then would die
Old 05-23-2009, 11:23 AM
Send a message via AIM to submariner Send a message via Yahoo to submariner
same thing kinda
i'll be driving for about 5 minutes and my truck will die, i'll still be coasting and i can start it back up. wierd. help please
Old 05-27-2009, 07:19 PM
That is definitely the camshaft positioning sensor. Its a little hard to reach but fairly easy to replace. And not too expensive. I think I paid $30 for one at a Ford dealership in the backwoods of Michigan.
Old 05-27-2009, 08:46 PM
Send a message via Yahoo to Jerryjust
CPS: Recall!!!!
Ford dealers will replace for free there is a recall on them. I have almost the same problem but my truck misses only when cold,when it is normal operation and driven about 15 minutes it smooths out and runs great. May be you know what is up with mine.????
Jerryjust
Old 05-30-2009, 02:00 PM
thanks a bunch i'll try that
Old 06-05-2009, 02:08 PM
so did replacing the cam shaft sensor work for you? cause it didnt work for mine.
