2000 E350 7.3 Chugging...Help!!!
I posted this in transmission problems a few weeks ago but didn't get anywhere with it. I'm still trying to figure it out so here it is again.
It doesn't do it all the time but it seems that when I drive down the road with the cruise on at 75 my van runs great. However, when I drop down to around 65 or lower and my van is still in OD I get a shudder, sometimes bad. As soon as I hit the accelerator it stops. It almost seems like the OD is too high for the speed that I am going and the van is trying to catch up with itself or something...If that makes sense. I have a superchips high performance programmer and code reader installed as well just in case that would matter.... Previous owner installed a rebuilt transmission in 04 with a "tugger" kit (I'm really not sure what that is). And had the injectors all replaced last year...He really kept up on the maintenance. So I hooked up the Superchips tuner and read the codes. I am getting a P0238 (Turbo Boost Sensor A Circuit High Input) and P1670 (EF Feedback Signal Not Detected) Both of which I don't know how to interpret. And a: P0460 (Fuel Tank Level Indicator Circuit Error) Thanks to the transflow, but I worked this one out. But nothing that points to what the problem is with the chugging I am getting in OD. I also pulled out a receipt stating that the PO had all new injectors installed on June 13, 2007 at a cost of $2006.00. Does anybody out there have an idea on what the problem might be? Also, how can I test the injectors to see if they are bad without pulling them and without getting a code? Also, it shutters a bit on take off and when I accelerate during normal operation. I've been reading something about a camshaft position sensor. Can this be the problem? Last edited by veg hed; 05-07-2009 at 05:56 PM. |
mines doing the exact same thing! shutter while in OD at low rpms! when i stop on it the shutter goes away. If i cruise at 75 runs like a dream but if i run at like 50 with OD on it shutters really bad.. Im in the processes of coming up with some money to get stage 2 injectors with a custom tuned TW chip. But most likely sounds like an injector problem
That's what I thought at first but mine are throwing the following codes:
P0238 (Turbo Boost Sensor A Circuit High Input) and P1670 (EF Feedback Signal Not Detected) And the PO replaced the injectors with new ones just last year. So I think something else is up...Has anyone else had a problem like this. I just need somebody to point me in the right direction. |
Anybody???
sounds like the torque converter, however check pump pressure. pump pressure is already low for that softer/smoother shifting.
Would that cause the following P codes:
P0238 (Turbo Boost Sensor A Circuit High Input) and P1670 (EF Feedback Signal Not Detected) I've done a little research and a bad MAP sensor can cause a P0238. How do I check to see if the MAP sensor is bad without buying a new one and replacing it. And what pump pressure are you talking about and how would I check that pump pressure. Torque converters sound expensive.... Thanks for the help... |
pump pressure guage used to test transmission when cold and hot, and in all forward gears, reverse, neutral, and park.
the engine shuttering would make those codes pop up.. You never get many codes from a transmission anyway and if your using your superchips programmer you wont get codes for it at all. The torque converter definatly sounds like your problem how many RPM's is the engine turning when it shudders? When the engine shutters are you blowing any smoke? The converter is a problem with the E4OD. Its usually what ruins the transmission I'd look into replacing your converter
Run a "buzz test" on the injectors (need someone to hook a scan tool to the PCM). Not sure thats the problem, but you'll at least eliminate them as a possible cause if they're good.
Did those things come with lock-up torque converters? That would make some odd behavior if its not working like it should.
