Cam sensor?
New fuel filter, new frame mounted electric fuel pump still no luck
Truck loses power when accelerating. Will cough and choke then all of a sudden it picks up and runs fine. Only when accelerating. Idles fine. No other problems except when accelerating. Could it be the cam sensor?
You mean CPS? Arent those pricy?
![]() Failed to mention that from time to time the truck also develops a sporadic idle. Will jump from 1200 up to almost 2000 at times then back down to almost shutting down. This isnt all the time though. Maybe 1 in every 10 starts or so |
Do you have a resistor in your ICP?
If so I would take it out. |
your symptoms aren't caused by the CPS. you may have a bad ICP sensor or your IDM is dying.
Actually, I agree with sldghamr's reply. I remember the same thing happening to my IDM last year, but it happened a lot faster & the truck died within 10min. If you can get your hands on a scan tool with functional test capability, I'd run a buzz test & see if any IDM codes pop up.
Had one at one for a short period of time but didnt like it at all. Took it out long before this stared. Could that have anything to do with this?
No I doubt it. Not if it came out a while ago, and you didn't have any problems til now.
sounds like icp issues,do like radar rider says and scan it and see what your icp is doing.
