Rough idle, low power, etc - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-23-2007, 09:24 AM Thread Starter
Hello there. This is my first diesel truck (yea.. i'm a n00b) and I am having some problems diagnosing an issue with this truck.
I have a '97 F-250 and recently replaced all the glow plugs, glow plug relay and changed the oil. I was hoping this would stop the rough idle issue but it has not. I have not yet tried cleaning out the fuel/water separator or changing the fuel filter because while changing the oil I noticed a very small leak in the fuel tank.
So, calling all pros... Do you think the rough idle might be a lack of fuel pressure, fuel filter or fuel/water separator, or all of the above? I do plan to fix/replace the issues above, but I am coming up with a game plan as to which one I should fix first.
Thanks for your time,
Matt
mmbrich is offline
post #2 of 14 Old 01-23-2007, 09:57 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
not any of the above probably ,very slight chance of a fuel pressure issue , probably a injector or two causin skip ,is it auto or manual
ITS STOCK
SCUFFY828 is offline
post #3 of 14 Old 01-23-2007, 10:23 AM
straycat's Avatar
Welcome to the forum, hope you get all fixed up.---Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #4 of 14 Old 01-23-2007, 10:30 AM Thread Starter
It's an auto. The truck has been chipped and I read somewhere that some of the programmers had bad firmware. Just thought I would throw that in to keep things interesting.
So injectors huh? I know I stumbled across a how-to for testing them. They're expensive little buggers though, any alternative to replacement? Like maybe a good cleaning or rebuild?
Thanks,
Matt
mmbrich is offline
post #5 of 14 Old 01-23-2007, 10:46 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
if there bad just replace them ,need to get someone to run some diag , check injectors both electrically and run a cylinder contribution test to verify which one , and make sure of any other problems
ITS STOCK
post #6 of 14 Old 01-23-2007, 10:46 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
Thanks,
Matt
Call Johnathan at Swamps and he can tell you if he can rebuild them or not...probably can and for half the price of new.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 14 Old 01-23-2007, 10:55 AM Thread Starter
Thanks for the input guys! I'll have to find a local shop to diag and then I'll decide if I want to try a rebuild or just go for new.
Thanks again!
Matt
mmbrich is offline
post #8 of 14 Old 01-23-2007, 11:37 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
No problem man!
post #9 of 14 Old 01-25-2007, 05:34 PM Thread Starter
I guess I should be careful what I wish for. I really didn't want it to be injectors and from the sounds of the diag, I wish it was.
Supposedly the injectors are fine, but the injector "harness" (the wiring harness that plugs in to the valve cover) are bad. That's not such a big deal, but they also said the harness 'at the truck' was bad and all together it would be around $1700 to fix it. Pfft.. I paid that much for the truck, no way I am going to blow that on some wires. Anyways, I plan to poke around some junk yards and see if I can find at least the 'at the truck' harness for less $$. If all else fails, I'll do my best to rebuilt it myself (I'm an engineer, can't be that bad right? .
Any further suggestion on this little situation are much appreciated.
Thanks!
Matt
mmbrich is offline
post #10 of 14 Old 01-25-2007, 05:36 PM Thread Starter
Oh.. and my first batch of biodiesel came out today. I put it in my wifes passat instead of the truck, but I can't wait to try it in that big monster!
Matt
mmbrich is offline
