Fuel Filter - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-22-2007, 02:47 PM Thread Starter
Fuel Filter
I'm going to be changing out my fuel filter for the first time. Does the cap just screw off or is there a screw(s) that needs to be undone first?
Thanks in advance for your help.
brush_buster is offline
post #2 of 7 Old 01-22-2007, 02:53 PM
DJM
DJM's Avatar
Nope the Cap just screws off. It's kinda on tight so you can buy the tool to get it off or make one or use a punch and a hammer just don't hit it to hard or it will break the fins off the lid.
DJM is offline
post #3 of 7 Old 01-22-2007, 02:53 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
welcome to the site!
The cap just screws off. what kind of truck do you have?
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 7 Old 01-22-2007, 04:48 PM Thread Starter
I've got a 2000 F-250
post #5 of 7 Old 01-22-2007, 04:51 PM
Just, rumove the filter topand install a new filter. The bad thing about your truck is the fuel drain valve tends to leak after draining the fuel. If you drain it, check for a fuel leak around the valve and out of the drain tube under the alternator.
Derrick
post #6 of 7 Old 01-22-2007, 05:11 PM
Fuel Filter Cap
The first time I was going to change the filter I took it in for a oil change and watched all the fluid changes. I even got under the truck. The way they pull the filter cam is with a 1/2 socket with no socket attached.
It's the easy way. Just be carefull not to get to carried away and break the top. barnyard
barnyard is offline
post #7 of 7 Old 01-22-2007, 05:37 PM Thread Starter
I was going to replace the o-rings in the drain valve so I will be draining the fuel. Thanks for the heads up.
