Engine Stall - Ford Powerstroke Diesel Forum
Old 02-06-2006, 05:40 AM
Exclamation Engine Stall
I Have A Problem With My 2001 Powerstroke. Engine Stall It Happens Mostly @ Idle. There Are No Werd Sounds, The Air Filter Is Clean And I Just Changed My Fuel Filter. Is There Anything Else I Could Possible Look At?
Old 02-06-2006, 07:28 AM
Send a message via AIM to purduefarmboy460
There are several other posts on the forum addressing this very problem. Have you been able to hook up a code reader?
look for CPS (cam position sensor) codes
Take a look at some of the other discussion in the 99-03 sections.
Let us know if you have more questions!
Welcome to Powerstroke.org!
Old 02-06-2006, 04:05 PM
cam sensor's the word for odd and random stalls...its not a bad fik, but don't make it if you're not comfortable with your wrench skills....
good luck
wes
Old 02-06-2006, 04:07 PM
make sure to pull the codes first...the most common reason for a stall is the cam sensor, but i have seen techs and customers make the mistake of assuming without making sure and it bites them.....it sucks to spend money and not fix anything....the cam sensor is not the only reason a 7.3 will stall even though by far it is the most common......Marc
Old 02-07-2006, 07:15 AM
Hey Thanks Alot
Old 02-07-2006, 07:17 AM
Thank You!
Old 02-07-2006, 03:07 PM
Originally Posted by pmonville
Thank You!
anytime man...
