Code Help! please
Ok like I said earlier this week, my truck engine light goes on and off when it wants. Before it didn't feel like I was losing any power but now I can tell that there is definately a power decrease when the light is on, maybe like 15 to 20 percent. When the light is off it runs just fine.
I scanned and got the folowwing codes: 1. P1280 ICP circuit out of range/ low 2. P0603 Internal control module KAM error 3. P1211 ICP pressure above/below desired The truck died on me once after i went to take off from idling for about 15 minutes. Started right back up. Then i was in line at the bank with the light off and it suddenly came on and the truck almost died ( sputtered ) and then kept running with light on. ???????????????????????? help
Try pulling the plug on the ICP sensor on see if there is oil in the sensor. If there is oil in the sensor its shot. The sensor is on the driversside valve cover towards the front. There is a thread in the 7.3 tech files that will show all the locations of the sensors incase you can't find it.
The plug area was full of oil......is that it those dang things are 175 at Ford, anywhere cheaper???? What would cause that? And what is the KAM error????????????????????
Thanks. |
I bought my sensor on ebay for 65 bucks. The KAM error is a common code. I think it is associated with having a chip. Its a harmless code.
