fluttering air
my truck is making a noise when i'm pulling a load up a hill. it will sometimes make the same noise when it shifts out. sounds like air fluttering thru a hole. the place that sold me the turbo said they would sell me another wastegate but in thier opinion, it would be a waste of my money. I've got a big airfilter and a banks wheel. would somebody please help?
First off what cfm is your air filter. The sound could be caused by a couple things. First off is Turbo Surge, the other would be the turbl trying to suck air through your filter, the third is just the waste gate bleeding off the extra boost.
Ok lets look at turbo surge. Surge occurs when the extra air in the turbo has no where to go. So it goes back out the inlet. If the surge is bad enough it will cause turbo stall. CFM and the air filter, if the cfm is not high enough the air filter is being to restrictive. Thus causing a constant whooshing sound of air. That whooshing sound is nothing more then air getting pulled through the air filter. A way to stop this replace the air filter with a higher cfm air filter. Remember the size of the filter doesn't matter. What matters is the cfm number. Now the third thing I was talking about waste gate bleed off. This is occurs when the psi level is reached and the waste gate opens up. The waste gate will remain opened until the psi level is lower then the rating of the wastegate. Now to determine what your problem is. Well you have the banks wheel, which is nothing more then the wicked wheel. So that should prevent your surge. But it does not always prevent it or stop it. So you may want to look at the bigger compressor housing. Air filter you did not mention what your cfm of your current air filter is. I know mine is around 900cfm. I do not have this problem. So like I said your air filter can be big but the cfm numbers have to be high. But do not sacrafice the filtering of the filter for higher cfm. Waste gate, well if it is opening often, or staying open for long periods of time. Then you may want to look into a different waste gate. |
thanks for replying! air filter is a duralite tymar, don't know the cfm. it's the big round one they show on this thread. the sound is something like this, sh sh sh sh sh. could you hear that thru the internet? haha. I know nothing about these things, but as i understand how the wastegate works, it makes me think that it is barely opening and closing when then pressure goes way up. i had a truck driver tell me the same and suggested to pull the vacuum line off the gate but it still did it. as i said earlier, ron's turbo said he'd sell me another but felt it was a waste of money. i'll try just about anything you suggest. thanks again.
Sounds like surge to me. I agree with pretty much everything bigcountry said except for the wastegate. You will never hear the wastegate opening.
ain't the banks wheel supposed to eliminate that? when your trans shifts out when your pulling hard what is the sound of air i am hearing released
