HPOP replacement - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-21-2009, 06:40 PM Thread Starter
HPOP replacement
Someone told me that if you replace your hpop it will cause your injectors to go bad. Is that true? I need to find a code reader so i can test it to see if it actually is weak.
08 F250 6.4 Lariat
MiniMaxx
4" AFE Downpipe back Exhaust
S&B intake
power4l is offline
post #2 of 7 Old 04-21-2009, 06:42 PM
a truck
Matt P's Avatar
replacing your HPOP will not cause your injectors to go bad
03 king ranch w/ a cummins
Matt P is offline
post #3 of 7 Old 04-21-2009, 06:47 PM
45_ACP's Avatar
haha who told u that
Early 99 F-250
4x4_____________________________PCT Welding and Fabrication Engineering
6-Speed
Gauges: Boost, Pyro, Hour
DIY intake
DIY Straight 4" exhaust
HPOX line
ITP diesel over boost inhaler
PHP Phoenix- stock, 80hp DD, 100hp Performance, 65hp Moderate Tow, SmokeShow, Anti-Theft
Leveling shackels
45_ACP is offline
post #4 of 7 Old 04-22-2009, 04:59 AM Thread Starter
My local mechanic told me that. He said if you get air in the oil and fuel lines after the hpop it can damage your injectors. Maybe i shouldn't listen to him anymore.
What's a good brand of scan tool to buy? I've seen some really expensive ones and some that are cheap and *****y.
08 F250 6.4 Lariat
MiniMaxx
S&B intake
power4l is offline
post #5 of 7 Old 09-15-2009, 04:48 PM
payne5757's Avatar
bump bump.....
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
post #6 of 7 Old 09-15-2009, 04:51 PM
Powerstroke W/smoke's Avatar
did he also say that if you burp and fart at the same time you'll have a heart attack? just messing with you man. what kind of issues are you having? low oil pressure?
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #7 of 7 Old 09-15-2009, 04:59 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
