EGTS Too High? - Ford Powerstroke Diesel Forum
Old 04-20-2009, 07:13 PM
Exclamation EGTS Too High?
I have a Edge Juice/Attitude and i think i have high egts for no more than what the chip is. At wide open throttle i can experience 1250+ in a short amount of time. Really the only stage that i cant get high egts in are stage 1 and stage 2, everything else i get 1250+. I thought that i might have a boost leak so i changed out all of the boots. No change. What else could be going wrong? I have noticed that i might have a small exhaust leak but would that cause egts to be high? and if it helps my egt probe is mounted in the driver side manifold. any help would be great.
Old 04-20-2009, 07:25 PM
I would say your up pipes are leaking... a "small" exhaust leak on the up pipes can make HUGE differances and loss of power/boost and higher EGT's.
Old 04-20-2009, 07:53 PM
did you check the boots under your intake spider? I had a boost leak and I checked all mine and found nothing. Staring at my truck i noticed one of the boots underneath had slid down a little for whatever reason. I put it back on properly and got much lower egts and 4 psi more.
Old 04-20-2009, 07:57 PM
i replaced those boots as well and everything seems fine. would you be able to notice a leak or how would i really check for one?
Old 04-20-2009, 08:00 PM
r there just gaskets in the up pipes or how do i go about fixing them without spending lots of money?
Old 04-21-2009, 12:26 AM
i have been doing some research 2night and would it be good to do a 1.00 turbine housing and a ATS compressor housing as well? I would love to get a GTP 38R but dont have that kind of cash right now.
Old 04-21-2009, 03:47 PM
Old 04-21-2009, 03:49 PM
im with everyone else... its more than likely your up pipes
Old 04-21-2009, 03:51 PM
where can i get a reasonable set at not a very high price?
Old 04-21-2009, 03:54 PM
of up pipes? i might get me a set of these: 1999.5-03 Ford 7.3L (Super Duty / Excursion) Upgraded Turbo Feed Tubes - FORD1837872C93
gonna have them coated just to see if it really makes that much of a diff....
also i would get that edge juice off of their as soon as you can.. it does nothing for your transmission and will eventually blow it
-Raul
