P1294 code - Ford Powerstroke Diesel Forum
Old 04-12-2009, 12:50 PM
P1294 code
I took my '01 out this morning after warming up and a nice easy idle down the drive and out to the street (1/4 mile).
When I got to the main road I pointed it straight and stepped on the gas.
It ran perfect for a second and then sputtered and chugged and puked smoke and then barely ran.
I pulled over and it kept idling until I shut it off.
I got it back home and it barely starts and SMOKES.
I did an injector buzz test and it says "Injector high side open Bank 2"
P1294
Any one know what I broke?
How to fix it?
2001 F350 4X4 7.3L PSD
DP tuner, 4" exh, 4" lift,
Old 04-12-2009, 02:27 PM
I forgot to mention that all drivers side injectors barely "buzzed" during the buzz test.
Old 04-12-2009, 02:32 PM
UVC harness came unplugged under left cover. Get the plastic wedges from Ford to put in to prevent this in the future.
Old 04-12-2009, 02:36 PM
So...I need to remove drivers valve cover and should see damaged/unhooked wires or connector?
Old 04-12-2009, 04:54 PM
Holy crap!
That was easy!!!
Thanks for the help.
Old 04-12-2009, 06:10 PM
Glad you got it!
