Truck Died on the freeway - Ford Powerstroke Diesel Forum
Old 04-11-2009, 01:14 PM
Angry Truck Died on the freeway
While driving to work on the freeway the check engine light came on I lost pwer and the thing died. I do not know what the problem is. The cam sahft sensor is new and switched it back to the ford recal one and still no go. New glow plugs, harness, bateries. The fuel bowl was full and the filter has only about 15K on it and looked good. Help
Old 04-11-2009, 01:17 PM
did it miss/spudder when it died? hopefully a tech will jump in for ya'
Old 04-11-2009, 01:39 PM
Ok I have codes, p1294, p1293, 1316, p1247 and p0340. On the 1294 and 93 are they supposed to be open.
Old 04-11-2009, 03:22 PM
Mike,
The 0340 is a CPS code and the others point to the IDM. I would start with replacing the CPS with a known good one. If that does nothing then I would suspect the IDM since you mentioned that you have checked the harness and fuses.
Old 04-12-2009, 02:26 PM
OK, it kinda looks like the 1294 code is the harness and that they may have become unplugged, kinda weird both sides at once. I did the harness a few months back and my friend who helped finish the project said they did not have the updated clips to secure properly. I did stumble across a ford harnes clip #2c3z-14a-163ab.
