mystery problem - Ford Powerstroke Diesel Forum
Old 04-10-2009, 01:13 PM
mystery problem
my 99 350 has strange problem runs great but 5 times out of ten when i turn wipers on it may cause engine to stall or if driving it will cut out on ocasion could there be a problem with combo switch or possibly ign. switch ? i'm baffled switch is about $110 bucks so don't want change if i dont have to truck has 202K on it
Old 04-10-2009, 01:29 PM
BeDevil
Have a truck that has an electrical problem every time you pull the steering wheel down to a comfortable position. My bet would be that there is something wrong with your wiring harness in your column
Old 04-11-2009, 01:57 PM
thanks im pulling steering covers off this weekend to check out
Old 04-11-2009, 09:34 PM
It almost sounds like there is a wire grounding out on you . I hope you are able to seeit when you get the covers off. It might be an idea to have your truck in a dark area when you get the covers of. If you cannot find a grounded wire just by looking try using your wipers and it might cause a spark if it is grounding out on you.
