Hot starting and ABS light 2001 PSD
I spent some time searching and did not find an answer. Here is the problem. Drove and turned off truck with warm engine. Sets 10 minutes and I try to start. Turns over great but will not fire. Put a boost charger on the battery and let set a while. tried to start 2 times until battery drains. Recharge and it starts perfectly. I get it home and check batteries, one has dry cells and is probably dead. Replace with good battery put on charger and truck starts. Runs great till I turn it off and will not start again without boost even though the starter turns it fairly fast. these are the things I have checked. Fuse 22 is not blown, tach bounces when turning over, I do get a wait to start light, some oddities are that the ABS light is now on if the key is in run position and the radio will shut off after key is in run position for about five seconds. Truck has lately surge in idle 1 minute after morning startup but will reset if I nudge it with my foot. In the last month the engine has died twice when Idleing. This is a 2001 psd f-250. Thanks for any advice
