Oh S*^%!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-02-2009, 05:46 PM Thread Starter
petec83's Avatar
Oh S*^%!!
Well it finally happened to me, Ive read on here about problems with the engine shutting off out of no where well here I am. So Im driving about 50 with the pedal steady and bam in shuts off, I look down and the SES light is on give it a bit of throttle and comes right back on again. Searched with my predator for codes. NONE. Went on for about 10 min happens again but comes right back on and runs fine. Came back home (about an hour and a half drive) and everything was just fine. Any ideas guys???
2000 F350 CC SB 4x4
6" lift
36" 15.5 ATZ Micky T's
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
Pyro, Boost, Trans Temp, Fuel Press. Gauges
petec83 is offline
post #2 of 7 Old 04-02-2009, 05:49 PM
dalton1's Avatar
replace the C.P.S.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #3 of 7 Old 04-02-2009, 05:53 PM Thread Starter
petec83's Avatar
Originally Posted by dalton1 View Post
replace the C.P.S.
Thats the cam position sensor right?
2000 F350 CC SB 4x4
6" lift
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
petec83 is offline
post #4 of 7 Old 04-02-2009, 05:55 PM
dalton1's Avatar
yep. my truck did the same thing and thats what fixed it.
If you take it to the dealer its a recall, they will fix it for free.
dalton1 is offline
post #5 of 7 Old 04-02-2009, 05:57 PM Thread Starter
petec83's Avatar
Even better!! Thanks alot bud
2000 F350 CC SB 4x4
6" lift
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
petec83 is offline
post #6 of 7 Old 04-02-2009, 06:02 PM
sldghamr's Avatar
even though i replace my CPS with the "improved" version, i still have a spare in the glove compartment.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #7 of 7 Old 04-03-2009, 04:08 AM
dalton1's Avatar
I always keep a spare too.
dalton1 is offline
