greetings all! am having a strange issue. at highway speed (usually while pulling a long hill or passing) the pig staggers (temp loss of rpms and boost-split second duration- almost like the alternator or ac compressor is coming on) this is quite random, somedays more than others. just wondering if this is common or if something is starting to go bad?
i usually drive with the chip on the higher settings (80 -120 hp). i have a six speed manual and this happens with the cruise control on. any feed back is appreciated and thanx in advance
was afraid that might be the problem
am saving pennies for the diagnostic software. for what it's worth i took a little road trip this weekend and tried different settings on the chip with the cruise on and off. it does it on every setting i tried and it doesn't matter if the cruise is set or not. interesting though it only does it between 7 and 7 3/4 pounds of boost. over or under and it didn't happen a single time. ideas?
will give that a try during the next turn on the highway and post results. thanx for the input.
allright, it's been awhile and i've been driving quite a bit. went into the settings and maxed out the low boost fuel adjustment on the chip. If it's not on the 120 hp setting and i'm not really pushing it the surge is gone. so... my guess is not enough fuel (maybe hpop pressure?) to support the chip in the higher settings. only diagnostics will tell. nough said for now.
