Wierd power problem Help pleas - Ford Powerstroke Diesel Forum
Old 04-02-2009, 07:12 AM
ok so replaced ICP CAS Fuel filter oil filter and the only code I get is glow plug module. Basically truck runs good up till 15 psi ...once it builds more then 15psi it seems like its defueling but if I push the pedal alll the way to the floor it seems like there is a burst of power that happens kinda like a surge and it seems like it surges on then off.....by surge I mean a surge of power
Old 04-02-2009, 03:54 PM
The Screwy HEUI
Any SES light or codes? Are you hearing a hissing noise @ all?
Old 04-04-2009, 03:26 PM
only code is for the glow plug module.
its basically from 15-26psi feels like its defueling at 90 percent throttle
at 100 percent throttle it seems to have more power and may be at full power 26psi
Old 04-04-2009, 07:09 PM
it probally is defueling...
Old 04-05-2009, 04:25 AM
The Screwy HEUI
Do you have a boost fooler?
Old 04-05-2009, 08:02 AM
no I dont....my tune is stock so shouldnt I only be able to make 16psi? Ill make a boost fooler today and see....also wouldnt I start to defuel at higher then 16psi?
Old 04-05-2009, 10:47 AM
The Screwy HEUI
You said your truck is losing power up to 26psi. Your truck will start defueling @ about 23-24.5psi. I think you just need a boost fooler.
Old 04-07-2009, 06:18 PM
boost fooler didnt help. What kind of software should I get for my in truck computer? I have PCMSCAN on it right now and it sucks.
Old 04-07-2009, 07:12 PM
The Screwy HEUI
You mean for diag, right?
Old 04-09-2009, 08:19 AM
well it does trouble codes fine but Id like to be able to see actual live datalogging and maybe tuning if available.
