Strange noise...any help would be appreciated - Ford Powerstroke Diesel Forum
Old 04-01-2009, 04:29 PM
I'm ready to pull my hair out....I've got a 2001 7.3 powerstroke it has 72,xxx miles....I have aquired a strange noise in the engine compartment....almost sounds like when you blow up a balloon...pinch the end and make it squeek...I know it sounds crazy... it only happens under boost about starting at about 1800 rpm and getting louder as it gains rpm....it sounds like its under the dash on the driverside...I removed all hoses...tubes...boots...etc.. to the turbo...all of them looked great...no holes...no anything...I took it to a local repair shop and they couldn't figure it out...I'm hoping someone else has has this problem....any help is greatly appreciated...thanks Shane
Old 04-01-2009, 04:58 PM
take off your IC boots, clean them, spray them with hair spray and put them back on nice and tight
Old 04-01-2009, 05:09 PM
I will try that...at this point I'm not beyond trying anything...the thing that keeps throwing me off is the fact it sounds like its around where the turbo sets...its very hard to hear with the hood open...but while driving very easy to hear....
Old 04-01-2009, 05:16 PM
make sure you clean the two beneath the spider (the intake where the turbo bolts to) there are two orange ones under there (atleast orange on my truck). It could very well be coming from there aswell.
Old 04-02-2009, 02:25 PM
I BELIEVE THERE IS A FORD TSB THAT MAY APPLY. TSB 03-21-49 LOOSE OR MISSING HOUSING BOLTS ON YOUR TURBO. THE FORD BOLT KIT IS 1C3Z-9G486-AA ABOUT 10 BUCKS AT DEALER. I DIDN'T THINK MUCH OF THIS UNTIL I CHECKED AN F350 AND SURE ENOUGH ONE BOLT MISSING AND ONE LOOSE. A SMALL SPLIT OPENED UP AND CAUSED NOISE, CAN ALSO CAUSE A POWER LOSS.
Old 04-11-2009, 10:56 AM
I will look into the bolt/missing bolts maybe thats it...last night I pulled the intercooler tubes and inspected...pulled the y pipe/spider...checked all the rubber boots...and still have the problem...maybe its missing some bolts...gonna check when the truck cools off...thanks guys !!!!
Old 04-11-2009, 05:27 PM
Ok I checked the housing bolts...no luck...all there and all tight...what else around the turbo could be leaking...from inside the cab thats where the noise sounds like its coming from....
Old 04-16-2009, 10:40 AM
to clarify, the bolts are between the two 'snails' at the center housing,there are four bolts and you will be able to see only two from the front, one on top near firewall and to see the last one you will need an inspection mirror to look behind the center housing. usually one or two are loose and one will be missing. also check for black soot at down pipe indicating an exhaust leak.
Old 04-28-2009, 11:12 AM
2000 Stroker Turbo Noise
Same Problem on My 2000 7.3, Around Aproximatly 1800 RPM, The Turbo starts to stutter, Getting higher pitched under a Load climbing a Hill. P.S Didn't notice until I put a an Edge Evolution on it.
Old 05-14-2009, 06:06 PM
im new here, this is how i found this site, i have the same problem on my 99 and was hoping to find some answers, i replaced all my air-air lines, still can't figure it out, it's drivng me nuts
