More help PLEASE!! - Ford Powerstroke Diesel Forum
Old 03-29-2009, 01:29 PM
More help PLEASE!!
First let me thank everyone who answered. Now I need some more help.
I replaced my fuel filter and that helped alot now I toke it to the store (2 miles) and on the way back I lost my throttle I pulled over and restarted the truck 3 times before I got response from the pedal. I limped it home and now I can start it and it will idle but I get nothing from my pedal no change in rpms it will run for about a minute and slowly die it will restart but still no throttle. As always money is tight and I am really in need of some help. Oh yea I had it scanned 3 days ago and found no codes. Has anyone had or heard of this problem and if so what the cause was. Thanks in advance
Old 03-29-2009, 01:47 PM
Send a message via AIM to troid123
Fill out your sig so we know what kind of truck you have.
Old 03-29-2009, 02:01 PM
Sorry
02 f 250 4 wd
6 spd manual
all stock
Old 03-29-2009, 02:05 PM
scuffs *****
Send a message via AIM to Tyler
DIRK!!! We need ya in here!
Honeslty I couldn't tell ya. Maybe the throttle position sensor went out, or there is bad oil press.
Old 03-29-2009, 04:05 PM
I let the truck sit for about a hour. I started it to move it into drive and seemed to be ok. Didn't take it on the road because I didn't want to be stranded. This has happened4 times in the last week. Really need to find out what's wrong please
Old 03-30-2009, 07:05 AM
How much fuel in the fuel tank?
Old 03-30-2009, 02:24 PM
over 1/2 tank. I also run diesel 911 in the winter.
Old 03-30-2009, 02:27 PM
Send a message via AIM to ABoyAndHisToys
Classic CPS (Cam Position Sensor) symptoms....Was the recall performed?
Old 03-30-2009, 02:29 PM
yes that was the first thing I did when it started acting up
I even crawled under the truck to make sure they changed it. The only reason the dealer did it was because it was under recall.
Old 03-30-2009, 02:32 PM
What about the fuel bowl. Can you see it filling?
