code reader - Ford Powerstroke Diesel Forum
Old 03-27-2009, 12:37 PM
code reader
Will a autoxray obd 2 scan code reader work on my 02 f350 7.3? Or will i need to use something specific to the diesel. thanks T Mac
Old 03-27-2009, 03:07 PM
The Screwy HEUI
It'll work as far as reading/clearing codes, but you can't do functional tests with it like buzz or contribution tests.
Old 03-28-2009, 07:55 PM
what testers work? can you say what brands of readers will do buzz and contribution tests?
Old 03-29-2009, 06:08 AM
Autoenginuity seems to be the most popular for the Powerstrokes. It works in conjunction with your laptop and is software based. You would need the Enhanced Ford Package to read all of the Powerstroke codes and it comes with the OBDII interface cable.
Old 03-29-2009, 07:07 AM
The Screwy HEUI
Well, the Snap-On Scanner's really popular with functional tests for PSDs. They're a dime-a-dozen on ebay & really easy to use. The problem with the Scanner is it's obsolete as hell(most Snap-On dealers won't even take it in for a trade!), & if you have more than 1 newer vehicle, it won't be very useful to you as Snap-On's stopped making software for the Scanner as of '08. I've kept my Scanner for the current vehicles my dad & I work on. After these vehicles are gone, it's time to save up for a Solus.
Old 03-29-2009, 07:15 AM
duct tape & zip ties
For the cost of a code reader that will only read codes. You can get Auto Enginuity that will do some tests and help you trouble shoot.
If you get Auto Enginuity you will ned the Ford Enhanced Powertrain package. Due to the fact that the Powerstroke Diesel is OBDII exempt.
Old 03-29-2009, 08:47 AM
thanks
Thanks for the info guys. Im trying to diagnose a hard miss in my 97 dps. no codes thrown. changed oil filter and fuel filter. im thinking i may need to drive it to get the old oil out of the hpos. any thoughts?
Old 03-29-2009, 08:49 AM
I am thinking you might have a bad injector.
Old 03-29-2009, 09:05 AM
The Screwy HEUI
+1 on bad injector.
Old 03-29-2009, 04:33 PM
leaking icp?
thanks for the input. put some atf in it today and drove it around thinking i would get some old oil out of the gallies and clean the injectors......no change then i smelled diesel under the hood. after a little wiping i found a diesel leak and i think it is the ICP ???? it is screwed into the fuel filter housing pointing out the drivers side of the truck. What do you think?
