powerstroke running weird? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-25-2009, 11:39 AM Thread Starter
2000 7.3 6speed's Avatar
So on tuesday my truck was running fine left home and went to mcdonalds and when i left went to pull out on the road and the truck accerlated very slowly untill it got close to 2000 RPM's then it ran fine. the first thing i checked was my chip i put it back to stock and no differnce. so when i got to school i put it on the scanner and got 3 codes
p1249- waste gate control valve performance.
p1247- turbo boost pressure low.
p1248- turbo boost not detected.
and the more i though about it it ran the same this way this winter when it was cold. and from what i understand this is normal in the winter to help warm up the motor. but why did it do this. when the motor was warmed up?
so i left school and it was running fine. and today it ran fine to.
my teacher told me to hook the wastegate up to a vacume pump to see if its working but i haven't had time to do that yet.
any one have any thoughts.
Thanks
2000 7.3 6speed is offline
post #2 of 3 Old 03-25-2009, 11:44 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
ebp valve can still act up warm if not operating correctly , check map sensor line from intake to map sensor also, just a starting point
ITS STOCK
SCUFFY828 is offline
post #3 of 3 Old 03-27-2009, 01:51 PM Thread Starter
I checked the line every all the hose clamps were tight. also i installed my boose guage in this line. and it is still working properly. is there anything else i should check for?
