Oil Cooler Leak? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-20-2009, 06:10 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Oil Cooler Leak?
Ive got an oil leak on my truck and I'm not sure exactly where its comming from. Valve covers are dry, block is dry, valley is dry, but the crossmember under the engine is wet. The wetness trails up towards the driver side. It looks to be coming from a big tube lookin thing that runs from the front of the motor to the oil filter under the driver side exhaust manifold. Its not a real bad leak, sometimes it doesn't seem to leak at all, othertimes after parking it, it will drip quite a few drops on the driveway. Any ideas?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #2 of 9 Old 03-20-2009, 06:33 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
BPS President
Jake is offline
post #3 of 9 Old 03-20-2009, 07:15 PM
That is the oil cooler and they can be disassembled and resealed.
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
post #4 of 9 Old 03-20-2009, 07:30 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
How hard of a job is that? How much for the gaskets and stuff?
BPS President
Jake is offline
post #5 of 9 Old 03-20-2009, 07:40 PM
orng1's Avatar
Quoted: 3 Post(s)
I think I have a leak too but I can't find it. Sounds similar to what you said but mine is on the pasanger side somewhere above the starter. There is a drop on the starter, I don't see a drop every time I stop but sometimes I get 2 or 3 drops over a spot and there is some oil over the transmission pan. Not leaking from there but stained as if it's smeared as I'm driving.
I'm hoping it's just residue from when I washed the engine.
Bob
2001 F250 SRW Reg cab, long bed, 80k miles.
Now with DP tuner, Airaid intake and 4" Magnaflow turbo back exhaust.
orng1 is offline
post #6 of 9 Old 03-21-2009, 05:55 AM
It's not bad, a little time consuming if you are anal about cleanliness like I am.(I'd probably never make it in a flat rate shop!) I seem to remember the 4 different o'rings and 2 gaskets came to around 40-50 bucks from the dealer, but don't quote me, it's been a while.
Russ
STOCK
Deeslfxr is offline
post #7 of 9 Old 03-22-2009, 03:43 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Would it be better to get the gaskets from ford or international?
BPS President
Jake is offline
post #8 of 9 Old 03-23-2009, 03:14 AM
Ron's power stroke's Avatar
i have a PDF file with removing and rebuilding the cooler with TQ spec's...if it doesnt post here send me a PM with your email and ill send it to you there..
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..shimmed 910's, DI push rod's, new alliant 315/200 hybrids, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
88 F250 7.3 IDI plow truck - bone stock
Ron's power stroke is offline
post #9 of 9 Old 03-24-2009, 08:44 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Thanks man. Where can i get more info like that for other jobs?
BPS President
Jake is offline
