Headgasket replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-14-2009, 07:57 AM Thread Starter
wd13's Avatar
I'm doing some research today to find out what is needed to replace my headgaskets. Last night on the way home it pressurized the coolant resivour and blew coolant all over the truck. Then I noticed the oil temp started to rise and the truck was bellowing white smoke with that anti-freeze smell.
Anyhow, was wondering if you guys could help me put together a generic parts list. I'm not sure what gaskets are reusable (if any), if the head bolts are TTY or not, etc. Also what are the torque specs on the heads?
Any and all help is appreciated. Thanks
wd13 is offline
post #2 of 3 Old 03-14-2009, 08:06 AM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
Wow that rough. Don't hear of too many 7.3's blowing head gaskets.
DON'T EVER REUSE GASKETS unless you want to do the job a second time.
I know Ford has a head gasket kit for the 6.0 that has more than what is needed. And I don't think you bolts are the trouque to yeild crap like mine.
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
post #3 of 3 Old 05-03-2011, 06:33 AM
your going to need 2 head gaskets,head bolts,a thermostat,and injector o-ring kits.you have to pull the injectors to get to some of the head bolts,plus you don't want to break an injector tip while removing the head.
Ford Senior Master Diesel Tech
ASE Triple Master-Automotive,Med/Heavy duty, and EVT
Firetruck Mechanic for City of Charlotte
2000 F350 SRW, 7.3,Banks 6 Gun,Diablo Chip and Propane injection
dzltech1 is offline
