fuel leak - Ford Powerstroke Diesel Forum
Old 03-12-2009, 12:15 PM
Send a message via MSN to Jesse.James
fuel leak
The other day i was working on my truck and i decided to drain the water out of the bottom of my fuel filter by cracking the valve. Now when i start my truck fuel drips out of it. It has to be that valve because its coming out the same place as when you drain it. any ideas?
Old 03-12-2009, 01:15 PM
JJR JJR is offline
Replace the o rings on your drain valve. The size is 1/2"odx1/4"idx1/8" thick. Make sure to get the Viton o rings because they will hold up to the ulsd fuel unlike the factory ones which shrink and leak. Should be able to find them at any local hose and fitting store for around a $1. Need two of them.
Old 03-12-2009, 01:40 PM
Plus you need the one for the top of the valve stem.
Old 03-12-2009, 09:19 PM
ok thanks guys. to get to these just take the fuel filter out?
Old 03-12-2009, 09:27 PM
Just drain the fuel bowl. HERE is a writeup on replacing all 3 of the drain o-rings.
Old 03-12-2009, 10:28 PM
thanks man!!
Old 04-04-2009, 09:14 AM
well that worked for about 2 weeks now its dripping again! can i just plug the bottom of the valve where the drain hose hooks on?
