replaced starter, now it wont hit over - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-10-2009, 05:51 PM Thread Starter
nic2fast's Avatar
The starter was making a noise when cranking, I changed the started and now it will spin over but wont start up. the only two things i did was, during removall i took it loose from the motor and left wires hooked up, had my wife try to start so i could hear if the starter was making the noise. had a brain fart becuase i forgot that it has to be ground to the motor to work. so it did nothing and then i remember about the ground. I wouldn't think that would have done anything but thought i would through it in there incase. The other things was i didn't disconnect the battery like most lazy people and it arched out once. not long though. other than those two things, it was a normal install. now it will spin over fine just won't crank up. I check all the fuses in the cab and under the hood, none are blown. ANY IDEAS???
99 F350 4x4 Crew Cab Duelly Flatbed
Automatic w John woods VB and HD converter
4:88 gears
Leveling kit
460,000 miles on truck 130k on motor
22.5 Peterbuilt wheels with 36" tires
Dp-tuner Chip
Gauges
4in Turbo Back Silverline Exh. into grand rock 6" mitercut stacks
Irate Diesel S366 turbo kit
Full Force diesel Stage 1 Injectors
DIY Intake
Terminator modded HPOP
Irate Diesel comp. fuel system with RR
Iron Bull Front Bumper with 12,5 winch
Reacon smoked cab lights and LED bed lights
nic2fast is offline
post #2 of 6 Old 03-11-2009, 02:41 PM
RadarRider's Avatar
Your batteries have enough juice, right? Truck's trying to crank but won't turn over? I know it's possible that this isn't related, but have you had your CPS replaced? Usually a short arc shouldn't do serious damage, but try taking the starter out & bench testing it.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #3 of 6 Old 03-11-2009, 07:24 PM Thread Starter
nic2fast's Avatar
$200 in batteries fixed it. thanks 4 the help
4:88 gears
Leveling kit
Dp-tuner Chip
Gauges
DIY Intake
nic2fast is offline
post #4 of 6 Old 03-11-2009, 07:27 PM
RadarRider's Avatar
No problems, man, glad you got it fixed! What did you get for batts.?
post #5 of 6 Old 03-11-2009, 07:38 PM
fordpwrstroke7's Avatar
Your avatar pic looks like you have more than just a leveling kit...looks good.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #6 of 6 Old 03-12-2009, 06:38 AM
RadarRider's Avatar
More ...you've got a pretty sweet looking lift, too. What do you have, fordpwrstroke7?
