NEED SOME HELP PLEASE ! - Ford Powerstroke Diesel Forum
Old 03-07-2009, 09:21 AM
JCW JCW is offline
02' F-250 7.3 powerstorke....superchip installed...It was hard to start and missed bad until it warmed up...then it ran fine. So I decided to change the glow plugs and injector o-rings ! After that it has ran worse ! , loss power, blowing oil out everywhere...up in tubro, in the valley . I took the oil fill cap off and there's alot of blow back ! I pulled the driver side valve cover. Cranked it up pulled the plug on each injector. 2 and 4 are working 6 and 8 aren't ! I checked the injector wiring harness had 1.3....and rotating votage on all 2,4,6 and 8. I pulled #6 and oil filled the hole ! I blew it out and pulled #2 and put it in the #6 hole....and 6 in the 2 hole....6 worked in 2 but 6 didn't work in 6 ! I checked the push rod and they are fine ! Anyone know what might be the problem ?
thanks for your help !
Old 03-07-2009, 09:25 AM
Check and see if your CCV is plugged or blocked real quick. When they are blocked they will turn your engine in to an oil fountain!
Old 03-07-2009, 10:37 AM
JCW JCW is offline
whats causing the oil to come into # 6 hole....no matter which injector i use?
Old 03-07-2009, 01:11 PM
She's paid for!!!!!!
Have you returned the program to stock?
Don't really know what could be wrong but here is a , maybe a Tech will jump in & help. Good Luck
Old 03-07-2009, 01:39 PM
JCW JCW is offline
yes I have...I have another 02 setting rt beside it and I have change MAP, ICP,.....trying everything I can and nothing yet...
Old 03-07-2009, 02:15 PM
JCW JCW is offline
LOOKS LIKE IM ON MY OWN......THANKS TO THOSE WHO REPLIED !
Old 03-07-2009, 02:47 PM
Are you sure the copper washer is on the injector still? Or one of the copper washers could still be in the hole and not be sealing it right
Old 03-07-2009, 02:51 PM
Also i would look into the wiring harnest with volt meter work from the valve cover back to were harnest comes lose next to finderwell
Old 03-07-2009, 04:53 PM
JCW JCW is offline
help
Every injector had a brass washer on the tip...so unless there was 2 on it ?...also I'm geting voltage from the side that in working with 2,4,6,and 8.
When it's running if i remove he plug off of 2 and 4 it make a difference.....But when I remove it off 6 or 8 it doesn't !....None of the injectors work in the 6 hole ! And the is the same voltage on all ! So 2 and 4 seems to work...6 and 8 doesn't ! What makes all injectors work in different holes but 6?...even with voltage ? Is it possibly a timing or sequence issue or what...I checked the push rods and It seems to have plenty of compression...
I can't figure this out someone please help !
thanks
Old 03-07-2009, 08:40 PM
duct tape & zip ties
Get a cylinder contribution test done.
